Crappy window regulator?
Old May 1, 2007 | 03:54 AM
98sleeper's Avatar
Default Crappy window regulator?
Yo i definetly think i have a crappy window regulator. Where can i get a new one for cheap or any opinons thinking its something else. The problem is the power has progressivley decreased in my driverside window. When i press the button it goes down about an inch then it takes at least 10 mins of driving to go down another inch. (it sucks goin to drive thru windows but its definetly funny)
Old May 1, 2007 | 11:01 AM
usarmyrangrs's Avatar
Default RE: Crappy window regulator?
If you want a cheap regulator or any other power window component, try eBay for parts. Autozone sells good OEM style parts, also. I found some of the best Camaro parts deals at www.partstrain.com. They have an ungodly amount of aftermarker and OEM parts for an honest fraction of what Autozone, Advance Auto, or even GM has to offer.
Old May 1, 2007 | 11:22 AM
uncle bill's Avatar
There is definitely something wrong with the gen 4 power window motors. I've seen numerious posts with problems and I've had to replace both of Mine on My 23,000 mile '96 Z28, and I've never seen one that goes up or down decently fast.
Old May 1, 2007 | 03:49 PM
98sleeper's Avatar
I heard that the stock window motors suck and if you go to a GM parts store they'll give you a revised one. I just looked at the parts train site and they had one for only 24 bucks but im not sure if its the same as the old regulator or the new one? If that makes any sense?
Old May 2, 2007 | 11:35 PM
purpl96's Avatar
I have the same problem in my 96 dude the people at White Castle now think I'm an idiotfor not rolling down the window to get my food, instead I had to open the door and get out. If your window has excessive movement when you shut your door with your window down at all then mine has the same problem.
Old May 7, 2007 | 05:37 PM
98sleeper's Avatar
My definetley has an unusual amount of movement. Im wonderin if the parts i get from ebay or partstrain are the revised or the first version of window regulator. Any have a clue.?
Old May 10, 2007 | 05:36 PM
fbjunior's Avatar
Hey guys that white castle reply was funny. I have a 96 crappy window motor also. Ebay sells them cheap but they have 2 models. After market replacement and oem. They say oem will out last after market. If your going through the touble to do it go oem in my opinion. 25.00 aftermarket 40 oem.
Old Mar 24, 2008 | 07:44 PM
tipdrip215's Avatar
very common problem on 4th gen. f bodies. both of mine went out at the same time i think i got a revised version of the motor when i got mine replaced becuz they make a different sound than the old ones did. goes down faster....isnt as noisy... and is just better overall
Old Mar 25, 2008 | 12:00 AM
libertyforall1776's Avatar
Nice revival of a post almost a year old! :-P
I replaced the drivers side regulator/motor on my 95 3.4L last year... About a year before that replaced the motor (but should have also replaced the regulator!)
Chaotic94
Feb 4, 2015 10:50 AM
burning camaro
Aug 9, 2011 06:57 AM
Kamaaina64
Feb 19, 2011 07:13 PM
MartineZ28
Jun 18, 2010 10:12 PM
TBenner80Z28
Mar 29, 2010 07:53 AM
