Project 96
#122
I paid $1000 for my car, and have put probably 3-4x that into it (mods and fixes) so far...so it could be worse haha
#123
Looks like this car will be put out to pasture this summer. Windshield cracked out of no where. I am thinking I might keep the motor and trans to put into some other project. Maybe a early 80's El Camino or a Monza.
The body has made it to 220,000 miles that is a 100,000 miles since I installed the motor. It is still getting 29-30 MPG. Not bad for a $2500 investment. Now onto project 93
#124
Sold it, hopefully the new guy continues this. He said he is going to fix it. Hopefully he doesn't find too many mistakes I made
#126
Continuing Project 96
I'm the guy who bought project 96. Just an update on it, I replaced the leaking coolant hoses and had a new windshield put in. Then I got the car inspected. The power steering pump blew so I'll be replacing that shortly. I have stuff planned over the summer for it and can't wait. Gorn, who I bought it off of is a top notch guy. I'm definitely gonna follow his builds. Thanks a lot.
#127
Sitting takes a toll on anything that relies on seals. I believe I replace the power steering hoses just a few years ago. Master cylinder may be suspect also but it never gave me a reason to work on it.
Just a reminder.
Back brakes, I never touched. They should be inspected closely.
Trans fluid should be checked. Again I never did that. If you look back in this thread you will see I used Royal Purple syndic if you need to add some. Fluid in the rear also, I never did anything to the rear, I always assumes I would be swapping to a posi/disk setup.
Might be a good idea to go over the underside of the car and look for rust spots and treat them with, permatex rust converter, then some paint after it dries. I have not done that since 2012ish. The hardware store in your town used to carry it. I bought some there in the past. In fact a lot of the hardware on the car came from their stainless bolt/washer section.
Plug and wires should be done at some point. They are from 2009. Funny thing is they are the AC delco OEM plugs and wires. I think they were $1.49 each and. All the sites were suggesting these crazy expensive plugs cause they would last longer. 8 years and 100k seems ok to me. Some of those recommended plugs were $12 per plug.
Good luck. If you need any parts and used is ok post here. If I have it, its yours. Last time I was at Joe's u-pull it they had 4th gens.
Just a reminder.
#129
So an update on the car, power steering pump has been fixed. Also, one of the coolant elbows cracked, so I replaced both with aluminum ones. I did the plugs and wires, I just did plain autolite plugs with ACDelco wires. The rear now has a 19mm sway bar off of a 96 SS I believe, as well as a black center panel (between the tail lights) from an SS. I just had the exhaust redone too. It's a 2 1/2 catback through a magnaflow muffler with feaux titanium looking tips. More to come soon, I love this car! Sorry about the photo quality
