MKCoconuts Z28 Project
Old Mar 16, 2015 | 09:08 PM
  #191
MKCoconuts's Avatar
Update. I've been lazy lately. Valve springs are on back order till 4/12 so it's kinda slowed me down some. I did get the front suspension all buttoned up.
Engine is almost complete.
Old Mar 17, 2015 | 04:04 AM
  #192
frankzlt1's Avatar
If you did swap to ls front brakes nows a good time. everything looks great though.
Old Mar 17, 2015 | 01:56 PM
  #193
MKCoconuts's Avatar
Thought about it. But the pads and rotors on the car currently are almost brand new and I never had any trouble stopping with the stock brakes, so I'm gonna get some new hoses and calipers and call it good.
Old Mar 26, 2015 | 11:02 PM
  #194
MKCoconuts's Avatar
Been a semi busy week. Got the underneath of the car clean up and truck bed lined. I went through the engine bay wiring harness and cleaned up the looms and retaped much of it.
Dropped the pan in transmission and wasn't pleased with the fluid. Smells a little burnt.
At least the magnet was doing it's job.
I finished cleaning the trans up and repainted it. I think it turned out nice.
Gonna get a new filter for the trans, refill with Dex VI, add a trans cooler and hope it lasts long enough to get another one.
Old Mar 26, 2015 | 11:07 PM
  #195
Eek! Was that fluid as brown as it looks in the picture?
Old Mar 26, 2015 | 11:19 PM
  #196
MKCoconuts's Avatar
Pretty much. Never gave any shifting problems though. Kinda bums me since I don't think there's more than 5k miles on the fluid.
Old Mar 27, 2015 | 12:18 AM
  #197
Oh man, only 5k on the fluid makes it worse. There's some serious slippage going on there.
EDIT: a few questions. Was the old fluid brown like this and smelled burnt too when you changed it 5k miles ago? Was it a pan drop and drain you did, or a complete flush? What type of fluid did you use?
Old Mar 27, 2015 | 01:09 AM
  #198
MKCoconuts's Avatar
To be honest, it's probably less than 5k miles, I'm really taking a guess on that because I don't remember exactly when I did it. I know I've done it twice, once when I first got the car and then once again.
The first time was just a pan drop. The second time I had it flushed out. Both times I put Dex III into it. I don't remember it smelling burnt or being that brown the last time I did it. I'll get a pic with my camera instead of my cell phone, and get a drip or two on some white paper from the valve body. What's in the drain pain is a little inaccurate because I believe there was still some engine oil in it from the last oil change I did, but the color seen coming out of the pan is accurate.
I should add that there were no shavings in the fluid itself. Only what was on the magnet.
Old Mar 27, 2015 | 07:23 AM
  #199
Your trans sure looks pretty on the outside, but very ugly on the inside!
With that low of miles on new fluid, it should still be a nice red color, and definitely not have a bad smell. Clutch pack slippage causing extreme heat is a reason for burnt fluid.
So would a non working trans cooling system overheat the trans, but the quick build up of metallic sludge on the magnet is saying internal issue.
Old Mar 27, 2015 | 10:27 AM
  #200
MKCoconuts's Avatar
It never shifted weird or unusual. Maybe I caught it early? I'll fill with new fluid and filter and hope for the best. All I can really do I suppose. A new transmission was not on the list of parts to replace. Haha.
