93-97 camaro v6 ls swap
Old Jan 1, 2019 | 06:02 PM
Thomas Wright's Avatar
Default 93-97 camaro v6 ls swap
i have a 94 camaro that is a v6. I want to do a ls swap to it with a 5.3 vortec engine. Have anyone on here did one before . Looking for any advise or tips. Thanks in advance
Old Jan 1, 2019 | 06:25 PM
Y2K's Avatar
Y2K
Quite a few threads on it,I think you'll find it's a pretty big headache to try but anything is possible.
The best way and to save a lot of hassle and money is to save your pennies up then sell your V-6 car and buy and LS powered car.
Old Jan 2, 2019 | 09:45 PM
One of your bigger issues will be the PCM. The 96 and 97 will not be as hard but the pre 1995 is OBD instead of OBD2. Since all LS style motors are OBD2 getting the PCM to work with older tech is going to require some skill.
Here is a good example of putting a 5.3 in a new 98-2002 V6
https://camaroforums.com/forum/93-02...v8-swap-78734/
If you read that you will see it is not cheap. It would be a lot cheaper to find a LS1 car will a blown motor and swap that. It would be a direct bolt in. By the time you get a PCM/ harness /trans and Kframe you pretty much paid for LS roller.
You could use the truck PCM as a stand alone system but the PCM drives the entire dash cluster. Building a custom gage cluster can be very pricey.
Mycahasiah97
Aug 1, 2018 11:13 AM
20862ls
Mar 8, 2018 07:51 AM
afronippleyo
2010+ V6 Tech
May 19, 2016 02:38 PM
Senshi09
Dec 26, 2011 06:21 PM
2000 project
Mar 28, 2011 09:50 AM
