Old Aug 8, 2012 | 08:28 AM
  #391
WIspartan1026's Avatar
May 2013 ROTM
thanks. looks like I'll be stopping at O'Reilly after work today
Old Aug 8, 2012 | 05:22 PM
  #392
May 2013 ROTM
O'Reilly didn't have any thread chasers. Going to have to go somewhere else to find that. Also, upon further review this afternoon, the STB and CAI look terrible. I'll repaint them tomorrow. it would sure be nice if I had something I could hang them from and paint them that way.
Old Aug 8, 2012 | 07:47 PM
  #393
May 2013 ROTM
tonight was one of those "work two hours and accomplish nothing" kind of nights. I can't get the EGR pipe removed because there isn't enough room for a ratchet and I can only get an end wrench on there in such a way that I can't actually turn it. I'm going to need to go to Home Depot to buy a hand saw, the thing I had isn't going to work at all and I have no sawzall (or a place to plug it in even if I did). The AIR fitting on the driver's side header came off easily, but I just about gave myself a hernia trying to get the one on the passenger side loose. I doused it with WD-40 again, so we'll see if that does anything.
Old Aug 9, 2012 | 11:58 AM
  #394
May 2013 ROTM
I talked a local tuner, and he said a tune would be around $450, but the big thing is that he won't be able to get me in for another couple weeks (everybody else wants their tune done before the Woodward Dream Cruise too). Will EGR and AIR being completely deleted make the car run worse without a tune? i.e., if it's back together and untuned, will it be running well enough to get to the Dream Cruise?
Old Aug 9, 2012 | 06:23 PM
  #395
May 2013 ROTM
Rainy day, so after watching the USA women's team win gold (), I spent about an hour and a half going to three different hardware/auto supply stores looking for thread chasers and caps for the AIR fittings. Went 0 for 3. Where do you think I could find these? I need the chasers more than the caps.
Old Aug 9, 2012 | 07:25 PM
  #396
call your local sears and see if they stock any Craftsman 48 pc. SAE & Metric Thread Restorer Kit - Tools - Hand Tools - Tap & Dies & Sets may be able to get overnight.
Old Aug 9, 2012 | 07:39 PM
  #397
you can make room by losening the bolts that hold the k member on to drop the motor an inch. would have to support the car by the frame and the k member with jack so you can lower and raise it. nothing wrong with leaving that tube and hooking to intake so long as the egr does not open then it does nothing.
Old Aug 9, 2012 | 08:14 PM
  #398
May 2013 ROTM
So far I haven't had much luck with Sears either. I'm looking at Summit right now. Is 1/4"-18 the same as 14" NPT?
The EGR valve is completely removed, so I don't have to wonder if it will be open...and I don't think dropping the motor would even help. If it goes down an inch I don't think it would create any space. The big issue is the orientation of the nut. Besides, I think dropping the K-member is a little beyond my capabilities with the tools and workspace I have at my disposal.
Old Aug 9, 2012 | 08:57 PM
  #399
1/4 inch pipe thread is 18 threads per inch. never heard of 14" npt except for 14 inch pipe and i have not used it before.
Old Aug 9, 2012 | 09:07 PM
  #400
May 2013 ROTM
that was supposed to be 1/4" NPT. Thanks though, I'll at least be ordering a chaser tomorrow, if not picking one up from somewhere.
