Water leaking in
Old May 24, 2007 | 04:58 PM
countryboy's Avatar
Default Water leaking in
I have a 96 camaro with t-tops and every time it rains water leaks in the seal where the door closes against the t-top. Itleaks on both sides but more on the drivers side. What can i do to fix this. If im driving it dosent really leak in only when its sitting there getting rained on while im at work. I keep it in a garage most of the time, but im looking at selling it and want to get it fixed if possible. Any help would be great. Thanks
Old May 24, 2007 | 08:18 PM
350rs's Avatar
March 2008 ROTM
Default RE: Water leaking in
might need to replace that chunk of seal on the t-top itself. I dont know if its the same on the 4th gen, but on my 3rd there is a seperate seal for the window to go up into on the top.
Old Jun 4, 2007 | 11:28 AM
1969 SS's Avatar
you probably need to replace your rubbers but one thing you might try just to check is put your windows up then shut the door. sometimes when the window motors get old they don't have enough juice in them to push up hard enough to give a good seal
Jeepin
Nov 23, 2011 11:32 AM
martybaker
Nov 16, 2008 08:27 PM
69RSSS
Sep 4, 2008 06:41 PM
th3po1son
Dec 11, 2007 07:09 PM
Damien8086
Jun 6, 2006 06:40 PM
