Water pump leaking?
Old Dec 11, 2007 | 06:08 PM
th3po1son's Avatar
Default Water pump leaking?
Okay maybe I'm just like, dumb as ****, but is there supposed to be a small hole in the bottom of the water pump, with like, fluid dripping out of it? I started the engine and let it run for 2 seconds and then a bunch of fluid dripped out of that hole... Is it just me or is there supposed to be something... there?
Old Dec 11, 2007 | 06:29 PM
th3po1son's Avatar
Default RE: Water pump leaking?
Alright I took a picture. I let my dad borrow my camera, so I had to use my cell phone. Thats why you can barely see it... so I labeled the hole and where the fluid is coming from (if it isnt obvious lol)
[IMG]local://upfiles/10532/C4D77EAD3EAF4FA0B6F669C21E724E10.jpg[/IMG]
Old Dec 11, 2007 | 06:55 PM
The seal in your water pump is gone, you need a new pump. That is called a weep hole and the only time it leaks fluid in a noticeable quantity is when the pump is shot. Change the pump as soon as possible because the water leaking on the optispark will cause it to die also.
Old Dec 11, 2007 | 07:09 PM
th3po1son's Avatar
Okay I thought I'd need a new one.
Jeepin
Nov 23, 2011 11:32 AM
martybaker
Nov 16, 2008 08:27 PM
69RSSS
Sep 4, 2008 06:41 PM
countryboy
Jun 4, 2007 11:28 AM
Damien8086
Jun 6, 2006 06:40 PM
