Brights lever doesn't work :(
Old Mar 21, 2016 | 04:14 PM
Cocoiscool's Avatar
Default Brights lever doesn't work :(
My brights are stuck on. The blinkers work fine it's just when I try to move the lever toward me it doesn't click and if I move it away from me nothing happens. Do I have to replace the lever or the switch in the steering colum ???
Old Mar 21, 2016 | 09:18 PM
GaryDoug's Avatar
There is a rod connecting the lever to the switch. See if the rod moves when you operate the lever.
Old Mar 22, 2016 | 03:20 PM
Cocoiscool's Avatar
It moves. What do I do
Old Mar 22, 2016 | 09:30 PM
try tilting the steering wheel up and try it. then try it tilting down. is the cover missing from the backside of the blinker switch base.
Old Mar 22, 2016 | 10:29 PM
Cocoiscool's Avatar
No and the switch is moving way back there. The brights are stuck on and I can't get them off
Old Mar 22, 2016 | 11:06 PM
GaryDoug's Avatar
Sounds like to me that the dimmer switch is either defective or has come loose. Either way, you have to get access to it.
Old Mar 24, 2016 | 10:31 AM
try getting plyers on the shaft and see if you can help it dim the lights. either the lever mount is moving to much or switch is shot. here is some info on the coluum. https://camaroforums.com/forum/93-02...mn-info-64804/ be better to download the factory service/shop manual here https://www.mediafire.com/?40mfgeoe4ctti
Old Apr 11, 2016 | 07:58 AM
torque_is_good's Avatar
More Information for AIRTEX / WELLS 3K9
$2 at Rock Auto, just re-route to a floor switch and call it done
mrdreex
Aug 5, 2010 04:18 PM
danlindquist1990
Apr 25, 2010 12:46 PM
jason7504
Aug 29, 2009 03:18 PM
89Frank
Aug 2, 2007 12:03 AM
fab
Apr 2, 2007 02:25 AM
