only my brights work!
Old Aug 28, 2009 | 11:49 PM
jason7504's Avatar
Default only my brights work!
when i pull the **** for my headlights, the dash lights up when i pull it to the 2nd click but not my headlights, only when i pull the **** to the 3rd position, the brights come on..is that the bulb that needs replacing or does it sound like somethings not plugged in right?
Old Aug 29, 2009 | 02:49 PM
3 positions? Is one of those positions "off"? On my car there's only two positions besides off. From off the first click is park litghts and dash lights. Second pos. is headlights and dash lights.
If you only have high beams with the headlight switch pulled all the way out, then hit the high beam switch and see if the lights go out, not to low beam. If so, your high beam switch is most likely bad.
Old Aug 29, 2009 | 02:50 PM
PS- before changing out the high beam switch, try testing the plug at the headlight to see if there's voltage. There's always that slim chance that both headlamps lost low beam filaments.
Old Aug 29, 2009 | 03:18 PM
so u have one headlight on each side? if so unplug the headlight turn on low beam and test the connectors to see if one of them are getting power. sould be three outlets one ground and two hots one for low beam and one for high. if no power to any of the outlets then its the wiring or switch. if there is power its the bulb.
BaD ToYz FoR BaD BoYz
Jul 29, 2011 06:54 PM
mrdreex
Aug 5, 2010 04:18 PM
danlindquist1990
Apr 25, 2010 12:46 PM
JaySan
LS Series Tech
Jan 3, 2009 09:24 PM
shrews61
Dec 17, 2008 11:50 PM
