LT1/LT4 Tech 1993-1997
Will these work
Old Dec 17, 2008 | 03:49 PM
shrews61's Avatar
Default Will these work
Im almost positive that the LT1s came with 24lb fuel injectors. One of the injectors on my car is bad, but its much cheaper to buy a set. Summit has a set from Accel that are rated at 26lbs, I have asked tech support and was told they will work without having to doany chip or computer modification. Is this true?
Any help much appreciated
Old Dec 17, 2008 | 04:35 PM
whammer3024's Avatar
ROTM Winner
Default RE: Will these work
if i were you...i wouldn't care what someone says. i'd get it tuned for the different injectors myself
Old Dec 17, 2008 | 11:50 PM
95slvrZ28's Avatar
If you're running a different injector I agree with Whammer, get it tuned, otherwise go stock. Unless you're running a head/cam car you're not going to need the extra flow of the larger injectors anyway.
383 Coupe Car
Mar 2, 2010 09:04 PM
Socom
Feb 16, 2010 12:46 AM
thatcamaro
Jan 25, 2010 04:47 PM
Z28Reggie
Aug 12, 2008 06:02 PM
92 RS in training
Jun 13, 2007 11:58 PM
