Won't idle. Running rough.
Old Jul 7, 2013 | 11:14 PM
You didn't mess with removing and replacing/reinstalling the timing chain set did you?
Old Jul 7, 2013 | 11:15 PM
Chaotic94's Avatar
September 2011 ROTM
Nope. Didn't pull the timing cover.
Old Jul 7, 2013 | 11:18 PM
I know it was running crappy before you took it apart to fix the leak, but was it popping out the exhaust at all like it is now?
Old Jul 7, 2013 | 11:20 PM
Chaotic94's Avatar
September 2011 ROTM
It was running fine before taking it apart. Just overheating.
Old Jul 7, 2013 | 11:22 PM
Oh ok, thought it was running rough too. Trying to exhaust (no pun intended) all other possibilities.
Old Jul 7, 2013 | 11:23 PM
Chaotic94's Avatar
September 2011 ROTM
Yeah. I don't know man. It's just frustrating.
Old Jul 7, 2013 | 11:31 PM
And you double checked your work to make sure all your vacuum, sensor, and electrical connections are hooked up?
Old Jul 7, 2013 | 11:32 PM
Chaotic94's Avatar
September 2011 ROTM
Yeah. Gonna check it again tomorrow
Old Jul 7, 2013 | 11:35 PM
Do you have the ability to do a leak-down test? You can check each cylinder at TDC compression stroke, and listen for air rushing out either the intake or exhaust. If it does, you have valve(s) that aren't seating fully. That would at least let you know what's going on without having to tear into the intake and valves again.
Old Jul 7, 2013 | 11:37 PM
  #20
Chaotic94's Avatar
September 2011 ROTM
I don't have the ability to do a leak down test. Ill just pull it apart tomorrow and re adjust the valves. I'm sure that's probably the issue...
