trouble starting! what do you guys think
Old May 11, 2011 | 06:09 AM
1997 rs camaro's Avatar
Default trouble starting! what do you guys think
before you can start my car you have to prime the fuel system and what I mean by that is you have to turn the key to the on position and let the fuel pump run till it shuts off then turn it off and then back on. You have to do this 2 sometimes 3 times. I already changed the fuel filter and my next route is the fuel pump. what do you guys think. I have a 97 RS.
Old May 11, 2011 | 10:31 AM
FI system is not holding pressure, possibly due to bad fuel pump (check valve leaking), leaky injector, bad pressure regulator, or external fuel leak.
Old May 11, 2011 | 07:07 PM
Thx! so now my next question where should I start checking before i go thru the hassel of replacing the fuel pump
Old May 12, 2011 | 11:00 AM
Get a fuel injection pressure gauge first. Then test the pump and the regulator, there are stickies on how to do it, or invest on repair manual for your car. If pump and regulator test OK, then check the injectors. This requres pulling the fuel rail with the injectors attached, then turn key to on to run fuel pump and observe if any injectors are leaking.
Old May 12, 2011 | 02:14 PM
i have moved both your threads. one to 4th gen and one to transmission tech. welcome to the forum and please read the rules.
Old May 12, 2011 | 07:09 PM
Ok craby thx
Old May 12, 2011 | 08:32 PM
shbox is good. go here and look things over. great site. 4th Gen LT1 F-Body Tech Aids
Old May 12, 2011 | 10:57 PM
thx again man
Old May 19, 2011 | 08:10 PM
Well guys it ended up being the fuel pump and here is a link to how I did my trap door. It worked like a charm. saved me any where from 6 to 10 hrs.
Fuel Pump Trap Door Mod---PICS! - LS1TECH
Chaotic94
Jul 7, 2011 09:49 PM
sgtdupree
Jan 17, 2011 11:05 PM
slinky32
Nov 30, 2008 08:34 PM
SilverBullet5
Aug 1, 2008 04:24 PM
94lt1camaro
Jun 25, 2007 08:38 PM
