Trouble Starting....
Old Jul 22, 2008 | 03:49 PM
SilverBullet5's Avatar
Default Trouble Starting....
Damn short posts.....car starts fine cold, once warm and sitting for a bit (off) trouble starting up again. Strong fuel smell after starting, sometimes dies on first attempt.
Changing plugs, wires, injectors soon, any ideas are appreciated, I'm thinkin fuel pump??
Thanks.
Old Jul 22, 2008 | 04:11 PM
evilkal's Avatar
Default RE: Trouble Starting....
Fuel pump is possible... Most likely plugs and wires if it's emitting a putrid fuel smell. Check your ignition coils as well.
Old Jul 22, 2008 | 10:31 PM
camaro_burns_all's Avatar
VIP member
I agree on checking the coils too.
I think the problem is with your electronic spark control (ESC). Its getting too hot, and losing ignition. You need to replace it.
Old Jul 23, 2008 | 01:56 AM
Guest
Guest
Posts: n/a
Fuel pressure regulator and Im 100% sure based on those symptoms.
Old Jul 23, 2008 | 03:09 AM
evilkal's Avatar
Even though it starts fine when cool? But that WOULD explain why it dies after starting with the fuel smell...
Old Jul 23, 2008 | 09:02 PM
Thanks guys, i'm well on my way toreplacing all those things already,also, my fuel gauge always says full unless i'm idling for a bit and then it drops down to what the actual level is...but goes right back up when I drive again...regulator?
Old Aug 1, 2008 | 02:25 AM
Bump...
Ugh, so it was plugs and wires, it started up instantaneously everytime after I replaced them, but one shook loose somehow so now my car is sitting at the gas station because it was shaking so much i didn't want to drive it...but i'll be tightening those in 4 hours before work.[:@]
Old Aug 1, 2008 | 02:42 AM
Guest
Guest
Posts: n/a
Your spark plug was shaking loose? Like out of the cylinder? Losing one plug wouldnt kill the car, it be the same as a misfire.
Old Aug 1, 2008 | 04:24 PM
Plug #6 was broken when I was putting it in I guess...but you were right, the main problem was the fuel pressure regulator, thanks again.
TripleZ
Jun 26, 2015 07:56 PM
Chaotic94
Jul 7, 2011 09:49 PM
TTopTyler
Apr 30, 2009 08:33 PM
slinky32
Nov 30, 2008 08:34 PM
Bubonic
Dec 2, 2007 06:01 PM
