Torque Converter Lock Up Solenoid
Old Apr 4, 2014 | 03:39 AM
Derek Tackett's Avatar
Default Torque Converter Lock Up Solenoid
Where's the Torque Converter Lock Up solenoid located on 93 camaro v-6
Old Apr 4, 2014 | 08:06 AM
Inside the trans, you have to drop the pan. Wiring goes to the 4th gear pressure switch on the valve body, over to the solenoid. How did you test and determine your lockup solenoid is bad, assuming that's why you're asking?
Old Apr 4, 2014 | 08:07 AM
drop the transmission pan and your there. download factory service manual.
Old Apr 8, 2014 | 10:38 PM
@Camaro 69...yeah i havet tested yet but idles great in park and nuetral but when it goes in ger...it acts completley different...really sluggish n boggs down
Old Apr 8, 2014 | 10:55 PM
So you're thinking the torque converter isn't unlocking? If that were the case, the locked-up torque converter would stall the engine, just as if you had a manual trans and didn't disengage the clutch. Does the engine still act sluggish if you put the shifter into 1st?
AboveTheLogic
Mar 15, 2012 04:25 AM
anthony7888
70-81 V8 Tech
Apr 28, 2011 02:29 PM
mr.blue
Apr 26, 2011 02:11 AM
1989_RALLYSPORT
Nov 12, 2009 10:35 PM
Jr. Mechanic
Aug 17, 2009 07:56 PM
