Torque converter lock up
Old Aug 17, 2009 | 03:28 PM
Jr. Mechanic's Avatar
August 2009 ROTM
Default Torque converter lock up
Alright, so last year I installed a TCI lockup kit on my 700R4. Never worked to say the least... Well today I took the car to the guy who built the transmission and we did some fiddling around with it and decided to just wire up the TCC solenoid direct. Well for whatever reason we CANNOT get the torque converter lockup to engage. We bench tested the solenoid, tried another solenoid, direct leads from the battery, etc.
He mentioned a mechanical lockup fix. He looked in his books and found a kit that replaces the valve above the TCC solenoid with a spring loaded valve that enables the lockup at a certain speed depending on which spring you use, thus eliminating all electrical connections. Sounded good to me, so I had him order it.
Does this sound like a good alternative?
Old Aug 17, 2009 | 03:45 PM
How many wires does your solenoid have?
Old Aug 17, 2009 | 03:50 PM
August 2009 ROTM
Two.
10 char
Old Aug 17, 2009 | 04:15 PM
Damn, that blew my "one-wire solenoid won't work" theory!
It's weird that you can't get it to work with testing more than one solenoid. It sounds like a wiring issue though. Thinking cap back on!
Old Aug 17, 2009 | 04:17 PM
August 2009 ROTM
We had the solenoid on the bench and it fired with a transformer and compressed air, so we believe the solenoid is firing when we power it, the TCC is just not engaging.
Old Aug 17, 2009 | 04:35 PM
Is the line from the vacuum switch hooked up to the right place? It's supposed to be hooked up to ported vacuum (you probably already know that), but you can also try hooking it up to manifold vacuum to see if that makes a difference. Vacuum needs to be more than 8-10 inches to engage the t.c. Have you checked your vacuum?
Old Aug 17, 2009 | 04:54 PM
August 2009 ROTM
The TCI kit is no longer on the car, like I said we have the TCC solenoid wired direct to hot and ground but it will not engage the lock up.
Old Aug 17, 2009 | 07:56 PM
August 2009 ROTM
http://www.superior-transmission.com...ic_lock-up.htm
http://racetransmissions.com/store/p...roducts_id=305
That's the kit that he's installing tomorrow. To me it seems simpler, more reliable, and less troublesome than the TCI kit, and eliminating wiring is always a plus to me...
I'm I looking at this correctly? What about when say I'm cruising at 70 MPH and the TC is locked. I punch it, will the pressure change automatically unlock the converter or will it stay locked past a certain speed?
Derek Tackett
Apr 8, 2014 10:55 PM
AboveTheLogic
Mar 15, 2012 04:25 AM
DeathProof
Jul 29, 2011 03:55 PM
anthony7888
70-81 V8 Tech
Apr 28, 2011 02:29 PM
1989_RALLYSPORT
Nov 12, 2009 10:35 PM
