Starter motor issue
#21
Okay, so now it sounds like you have a 5-speed. No WAY will that flywheel crack. It does now sound like a starter or starter mounting problem.
With regard to shims, the shop I go to is routinely replacing starters. I've looked at a few rebuilt ones and all were marked "NO SHIMS" right on the aluminum casting. Don't understand how that can be.
#22
Your start solenoid engages your over running clutch into the gears of your flex plate. The overrunning clutch job is to disengage the starter gear once the flexplates speed is greater than the the starters speed, which is why it is called the over running clutch. When the over running clutch fails the starter does not disengage and has to wait for the human to release the solenoid. This will destroy the teeth on the flex plate or flywheel.
There is no part of your starter that has anything to do with a bendix, Bendix is an old term from an obsolete design that has not been put into a car in 40+ years. Standard transmission cars have flywheels automatic cars have flex plates.
Once you install 20-30 starter you can hear the differents between too much clearance and not enough clearance. When the starters are too loose they have a tinny or springing sound, when they are to tight they have more of a grinding sound and they will not disengage instantly.
Addon: Anytime you see the marking "NO SHIMS" it is because in the manufacturing process is design to meet a factory requirment. This would only happen if the engine itselt was designed to meet a given assemby tolerance and the starter meets its tolerance the combind tolerance can be handled by the gear teeth. In laymen terms the OEM spent the money to build an assembly that needs no adjustment. If an after market "No Shims" start needs shims its because their rebuild process did not meet the original factory spec.
#24
Verry good info.....It helps a lot, thanks...so on my old starter the ring gear would just spin without engage the flywheel. also ,how much can i shim past the 1/8" whth the hope the ring gear well mesh with the flywheel..It all works good as long as the gear doesent tap the flywheel.
#25
Gorn, yeah that's true, but people still lovingly refer to the gear as a bendix gear. Just like making a "Xerox" copy, even though you're using a different brand copier. Another one is the carry-over from pre smog days when the vacuum advance was hooked up to manifold vacuum, but people are still instructed to disconnect that (vacuumless) ported vac hose from the distributor when setting the timing. Some things never die.
