squeals when I turn left
Old Oct 14, 2013 | 07:59 AM
Since it's rhythmic to wheel rotation, it's likely to be the pads moving against the caliper bracket. Hit the brakes, and the pads stop moving.
Try this stuff, you only need to coat the contact areas: Disc Brake Quiet
Old Oct 14, 2013 | 08:25 AM
Tipsy's Avatar
Thanks! I'll pick some up today. Do I use this in addition to the caliper grease I already applied or should I clean everything off and start fresh again?
Old Oct 14, 2013 | 01:22 PM
Clean the grease off. The Brake Quiet is a coating that sets up, not a grease lube.
Old Oct 14, 2013 | 01:53 PM
i thought brake quite was for the pads, brake grease was for the sliders.
Old Oct 14, 2013 | 03:54 PM
I was reefering to using the Brake Quiet on the pads. I thought that's where he put the grease.
Old Jul 5, 2016 | 07:32 PM
Tipsy's Avatar
Finally figured this one out! Found my drivers side rear caliper guide pin was loose and because of that it was missing most of its caliper grease. Tightened it, greased it, reassembled it and the noise is finally gone! I am ecstatic!
den510
Sep 16, 2013 02:07 AM
JZ28
Mar 31, 2012 09:13 PM
Phalen123
Oct 31, 2010 03:06 PM
Cobalt
Oct 18, 2009 09:24 PM
sethscamaro01
Jun 11, 2007 11:47 AM
