Springs/SS Hood
check the sway bars on front and back to see if there installed right. i know the rear one can mess things up is its not tightened the same on both sides. also on the rear the spring isolators are shaped for the spring to set in them a certain way and if they are not one side will set higher. also look over the front shock perch (round steel ring that goes around the front shock and holds the bottom of the spring) it may be jammed part way up or has slipped down because of rust or damage. probly better look there work over and see if theres a wrench or something sticking in the spring and shock areas.
