Springs/SS Hood
Old Aug 10, 2012 | 06:35 PM
Slick6's Avatar
Old Aug 10, 2012 | 06:37 PM
Slick6's Avatar
You can see in both of the bumper pics that it leans to the driver side a bit. Side shots front to back doesnt look too bad, guess I was expecting the front to be little lower.
Old Aug 10, 2012 | 10:26 PM
check the sway bars on front and back to see if there installed right. i know the rear one can mess things up is its not tightened the same on both sides. also on the rear the spring isolators are shaped for the spring to set in them a certain way and if they are not one side will set higher. also look over the front shock perch (round steel ring that goes around the front shock and holds the bottom of the spring) it may be jammed part way up or has slipped down because of rust or damage. probly better look there work over and see if theres a wrench or something sticking in the spring and shock areas.
Old Aug 10, 2012 | 10:55 PM
wow that does look low, what wheels and tires you have on her?
Old Aug 11, 2012 | 05:58 AM
Slick6's Avatar
Im running the C6 (obviously) 18/9.5 -- 275/40/18
Slick6's Avatar
Im still not sure why those corners are off.....?
Old Aug 11, 2012 | 09:17 AM
Krusher RS
May 23, 2013 11:51 AM
coylebailey
Nov 1, 2011 08:32 PM
coylebailey
Sep 27, 2011 05:57 AM
2Slow4You
Aug 3, 2009 08:19 AM
ScottD
Oct 27, 2006 06:37 PM
