RS body kit connectors?
Old Jun 11, 2012 | 09:08 PM
DDRDiesel's Avatar
Default RS body kit connectors?
Can anyone tell me where to find the mounting hardware for the stock RS body kit? All I could tell you was that it appeared to made up of hard rubber grommets pushed into a sort of anchor to secure the kit against the body. I would love to put up a picture for reference, but I had to cut them to take the kit off in the first place. If I can't find GM-certified fasteners, I'll most likely end up using a bolt and anchor kit from Home Depot (Zinc-plated to avoid rusting, of course)
Old Jun 12, 2012 | 10:12 AM
Shad0wguy's Avatar
Tried gmpartsdirect.com?
Old Jun 12, 2012 | 10:36 AM
you need to look for the part number first. in this case i was seeing 12531209 here http://performanceworks1.com/PDF%20F...s%20Manual.pdf originally but it seems to have been changed to 12531210 as seen here F MOLDINGS/BODY (RS)(Y3F);. Fits: Camaro, Camaro Z28 | Nalley Buick GMC Brunswick
best price i could see on a quick search
GM Parts Direct: Your direct source for Genuine GM Parts
Old Jun 12, 2012 | 11:22 AM
DDRDiesel's Avatar
You're all right, craby, no matter what they say about you . But seriously, thanks for the heads-up. Not sure why 'Retainer' was highlighted when I just need the rivet, though
bd92rs
Aug 3, 2011 12:54 AM
gagger84
Feb 27, 2011 08:17 PM
1989fbody
Jan 18, 2010 09:22 AM
mountaindewguy
May 11, 2009 01:26 PM
nabisco
82-92 V8 Tech
Aug 25, 2008 07:58 PM
