RS body kit connectors?
Can anyone tell me where to find the mounting hardware for the stock RS body kit? All I could tell you was that it appeared to made up of hard rubber grommets pushed into a sort of anchor to secure the kit against the body. I would love to put up a picture for reference, but I had to cut them to take the kit off in the first place. If I can't find GM-certified fasteners, I'll most likely end up using a bolt and anchor kit from Home Depot (Zinc-plated to avoid rusting, of course)
Tried gmpartsdirect.com?
you need to look for the part number first. in this case i was seeing 12531209 here http://performanceworks1.com/PDF%20F...s%20Manual.pdf originally but it seems to have been changed to 12531210 as seen here F MOLDINGS/BODY (RS)(Y3F);. Fits: Camaro, Camaro Z28 | Nalley Buick GMC Brunswick
best price i could see on a quick search GM Parts Direct: Your direct source for Genuine GM Parts |
Originally Posted by craby
(Post 629674)
