Replacing a fuel filter on a 3.8 V6 (any advice?)
Old Nov 21, 2012 | 02:23 PM
RPDRed6's Avatar
Question Replacing a fuel filter on a 3.8 V6 (any advice?)
Hey all-
First, I hope everyone has a great and happy Thanksgiving.
Second, I'm looking to replace the fuel filter on my 2001 Camaro 3.8.
I've never done it before and was going to go by this as a guide: Fuel Filter Replacement - InstallUniversity.com LSX, Lexus, Mercedes-Benz, and Apple
Does anyone have any tips for doing this specifically on a V6 or is it pretty similar? Do we have a Scharder valve to drain pressure on our 3.8 engines (as seen in step 4)?
Thanks!
Robby
Old Nov 21, 2012 | 03:58 PM
MKCoconuts's Avatar
Haynes/Chilton manual would help more and will help with later issues. Not too much to it. Make sure you have a rag handy to keep fuel from spilling and making a mess. I don't remember if the 3.8 has a test port or not. Make sure you got quick disconnects and all the right tools. Other than that, it's like a 30 minute job, if that.
Old Nov 21, 2012 | 04:18 PM
Jim in Indy's Avatar
On my '96 3.8 there is a schrader valve on the left (driver's) side of the engine, on the fuel rail. Use a rag, and tap that center pin you'll see with a valve stem cap (or similar tool) and the residual pressure will bleed off in a couple seconds.
Make sue your fuel tank is below 1/4 tank, loosen the gas cap to let any internal pressure from the tank escape, use a back-up wrench on all fittings, and watch your eyes when you remove the old filter.
Also, do the filter change where there's plenty of ventilation.....
Old Nov 21, 2012 | 08:56 PM
other than the test post it should be similar to this 4th Gen LT1 F-body Fuel Filter Replacement
OptimusPrimer93
Apr 4, 2013 12:38 AM
jon_uscg2001
Aug 25, 2011 12:23 AM
stan1277
Aug 2, 2010 09:56 AM
akleeve
82-92 V6 Tech
Feb 11, 2010 08:34 AM
johnson3034
May 25, 2007 09:35 PM
