project that wont start
check fuel pump relay. its under the diver side kick panel. number 36 on the list here 4th Gen LT1 F-Body Tech-Component Location Views
ok, dang, i dont have anything on the 96 3.8 wiring. most switches on these are ground switched so it may be a ground that is switching. check to see whats going on with the ignition switch, its at the base of the steering coluum. i think the vats wiring is the same as whats on shbox. http://shbox.com/1/bcm_1996.jpg i see the body control module controls the fuel pump enable so finding more on it would be a good step.
