help 94 3.4 wont start
Old Feb 11, 2007 | 08:14 AM
moonlighter's Avatar
Default help 94 3.4 wont start
turns over fine but wont fire have checked module ok.new crank sensor new cam sensor has no fire and no puls to injectors has 40 lbs to fuel and computor has been replaced ??????? any ideas
Old Feb 11, 2007 | 01:53 PM
Default RE: help 94 3.4 wont start
Have you checked the module or the coil pack, or both. Being that you changed everything else, one would suspect a wiring or connector problem. You need a scan tool, not a code reader, and verify what the PCM is getting from the sensors.
Slundy12
Dec 11, 2011 07:57 PM
Luz Hernandez
Feb 26, 2011 09:17 PM
mjstempky
Feb 19, 2011 01:17 PM
jpkz94
Jan 21, 2011 01:47 PM
89Rally
May 3, 2007 01:49 AM
