help 94 3.4 wont start
turns over fine but wont fire have checked module ok.new crank sensor new cam sensor has no fire and no puls to injectors has 40 lbs to fuel and computor has been replaced ??????? any ideas
RE: help 94 3.4 wont start
Have you checked the module or the coil pack, or both. Being that you changed everything else, one would suspect a wiring or connector problem. You need a scan tool, not a code reader, and verify what the PCM is getting from the sensors.
