project that wont start
Old Apr 2, 2012 | 02:12 PM
check fuel pump relay. its under the diver side kick panel. number 36 on the list here 4th Gen LT1 F-Body Tech-Component Location Views
Old Apr 2, 2012 | 02:47 PM
slim's Avatar
Only power going into it is orange wire and its got power with key on and off and no other wire has power
Old Apr 2, 2012 | 09:17 PM
ok, dang, i dont have anything on the 96 3.8 wiring. most switches on these are ground switched so it may be a ground that is switching. check to see whats going on with the ignition switch, its at the base of the steering coluum. i think the vats wiring is the same as whats on shbox. http://shbox.com/1/bcm_1996.jpg i see the body control module controls the fuel pump enable so finding more on it would be a good step.
Old Apr 9, 2012 | 06:05 PM
slim's Avatar
got car towed to repair shop got it diagnosed and it is bad computer new one is on order will see what happens tommrow when arrives
94camaroZ28
Apr 19, 2007 11:07 PM
muscleman
Mar 16, 2007 04:00 AM
6v49der
Feb 16, 2007 12:02 PM
moonlighter
Feb 11, 2007 01:53 PM
grandstax
Jul 22, 2006 09:32 PM
