power wires
Old Nov 23, 2018 | 05:43 PM
iafrate's Avatar
Default power wires
I did the series II swap to III and I have almost everything back together and I got it started today but I have a power wired that I have no clue where it goes. its one of the ones that come off the positive of the battery, one goes to the starter I have the black wire going to the fuse box but I one left over that I'm lost where to put it.
Old Nov 23, 2018 | 07:35 PM
peterpar's Avatar
Help me out here, what is a series II to III swap? Are you saying the positive battery cable has three conductors coming from it? Most late models will have a conductor to the starter solenoid, another to the underhood fuse box and last one to the alternator.
Old Nov 23, 2018 | 09:31 PM
iafrate's Avatar
Old Nov 23, 2018 | 09:32 PM
iafrate's Avatar
I took an engine out of a 2006 Buick which has a series III 3.8 in it. Anyways the black wire goes to the fuse box, one of the red goes to the starter and I have one more red wire, the alt is already connected and running. The wire has a ring connected at the end so it bolts down somewhere
Old Nov 23, 2018 | 10:15 PM
peterpar's Avatar
Not sure how you have the alternator wired, but here's are several drawings from the 1996 Camaro Service Manual showing the battery cable terminations. There should be a cable from the large stud of the alternator to the positive post of the battery in order to recharge the battery.
File Type: pdf
Old Nov 24, 2018 | 12:14 PM
iafrate's Avatar
Ok yeah I see what you are talking about now, thank you!
rob.del5
May 30, 2018 11:01 PM
DanG_1967RS
67-69 V8 Tech
Sep 19, 2017 07:38 AM
camaro468
Aug 16, 2012 01:56 PM
littlecmac
Jul 4, 2011 07:19 PM
BasicConcepts
Jun 14, 2010 07:31 AM
