power wires
I did the series II swap to III and I have almost everything back together and I got it started today but I have a power wired that I have no clue where it goes. its one of the ones that come off the positive of the battery, one goes to the starter I have the black wire going to the fuse box but I one left over that I'm lost where to put it.
Originally Posted by iafrate
(Post 729473)
I took an engine out of a 2006 Buick which has a series III 3.8 in it. Anyways the black wire goes to the fuse box, one of the red goes to the starter and I have one more red wire, the alt is already connected and running. The wire has a ring connected at the end so it bolts down somewhere |
1 Attachment(s)
Not sure how you have the alternator wired, but here's are several drawings from the 1996 Camaro Service Manual showing the battery cable terminations. There should be a cable from the large stud of the alternator to the positive post of the battery in order to recharge the battery.
Ok yeah I see what you are talking about now, thank you! |
