no strt prob.....HELP!!!
Old 02-18-2015 | 08:12 AM
are you getting power to the fuse box? better get the volt meter out and start checking around. could be a ground or hot wire problem. you have a power and ground junction boxes on the passenger side fender well, be a good place to start. did the air bag go off?
Old 02-18-2015 | 09:45 PM
GaryDoug's Avatar
It's a 2000. The power junction terminal is on the driver side next to the two fuse/relay boxes. The ground body terminal is on the passenger side wheelhouse.
Old 02-20-2015 | 03:36 PM
ChevyGirl80's Avatar
Default Problem Solved
Well yall we finally figured out what was wrong with my car...it was a BLOWN fuse,gauges fuse!!!! All that time,wow. We had checked the fuses under the hood but forgot about the ones inside the car. Anyways I just dropped her off at the paintshop. Ill post pics as soon as I get her out. Yayyy!!!!!!!
Old 02-20-2015 | 03:40 PM
GaryDoug's Avatar
Kudos to "Camaro 69" for calling that one.
95z28htch
12-30-2009 02:18 PM
94 b4c
03-07-2009 10:48 AM
lilwill
08-29-2008 10:48 AM
bluovlh8er
05-16-2007 08:51 PM
dzroc
06-28-2006 06:04 PM
Quick Reply: no strt prob.....HELP!!!
