A lil prob for a Lil car
Old Aug 27, 2008 | 10:41 AM
lilwill's Avatar
Default A lil prob for a Lil car
alright i can't figure out where my leak is. i believe that it is power steering fluid because i have to fill it nearly once a week. wheneer i park it leave a trail of it and when i do pull into a parking spot sometimes, it just pours out. I'll even stop at a light and I can see smoke rising out of my car. I don't know if its the resvoir or a hose. any suggestion?
Old Aug 27, 2008 | 11:19 AM
LT1RUNNER's Avatar
Default RE: A lil prob for a Lil car
Smoke or steam? Have you just checked where the leak may be from when the car is idleing? Have you got under the car to see where the leak may be from. If it's the power steering then your hoses may need to be replaced. Oh and by the way it's easier to diagnose a problem with a car when you know what kind of car we are talking about here.
Old Aug 28, 2008 | 06:31 PM
lilwill's Avatar
well since this is a camaro forums..its a camaro. 1995 v6 3.4L. and its smoke (smells like burning rubber) and ive tried to find the leak but im a total dumb@$$ when it comes to diagnosing a problem
Old Aug 28, 2008 | 06:49 PM
LT1RUNNER's Avatar
ORIGINAL: lilwill
thwell since is is a camaro forums..its a camaro. 1995 v6 3.4L. and its smoke (smells like burning rubber) and ive tried to find the leak but im a total dumb@$$ when it comes to diagnosing a problem
I pretty much figured that part out. Reason I asked is because different years had their own set of problems and if it's a V8 or V6. That too would change some things. Look for the power steering pump. Have someone turn the wheel with the car running. You should be able to detect where the leak is coming from because of the presure inside the hose. It will shootthe fluid out of where ever the leak is. Pretty simple just be careful because the car will need to be running.
Old Aug 28, 2008 | 06:56 PM
lilwill's Avatar
ok cool. now ho much would new line cost. or if thigs were really bad a new resevoir
Old Aug 29, 2008 | 10:48 AM
LT1RUNNER's Avatar
The hoses are not expensive at all nor is the pump. When the pump goes bad you'll usually hear a whine everytime you turn the wheel. If you're not hearing that then I'd look to the hoses. Wash that area with some degreaser so it will be easier to detect where the leak may be. Since you have access to the internet then you can go to Autozone.com or CSK and see how much the parts are online before you go to purchase them. Just gives you a heads up of how much you're going to spend. Good luck!
95z28htch
Dec 30, 2009 02:18 PM
94 b4c
Mar 7, 2009 10:48 AM
bns68ss
Apr 8, 2008 09:24 PM
bluovlh8er
May 16, 2007 08:51 PM
91_cam
Feb 25, 2007 04:44 PM
