SAD NEW CAMARO OWNER.
Old Aug 26, 2008 | 07:21 PM
88rocksu's Avatar
Default SAD NEW CAMARO OWNER.
Ok I just bought a 2001 camaro with the 3800. SHE HAD A RUFF IDLE SO I PUT LUCUS INJECTOR CLEANER IN IT AND NOW WHEN I MASH THE GAS THERE IS A BAD STUMBLE. IF I FEATHER THE THROTTLE ITS NOT THERE. THE TECH II TOLD ME THAT THERE WAS A FAULT ON # 5 CYL. I REPLACED THE PLUGS AND WIRES AND STILL HAVE THE SAME PROBLEM. I TOOK OUT THE K&N AIR FILLTER AND INSTALLED A FACTORY AIR FILLTER THINKING MAYBE IT WAS AN AIR PROBLEM AND STILL THE SAME PROBLEM. HOOKED UP THE TECK II AND NOW ITS BOUNCING AROUND ON DIFFERENT CYL. I THEN WENT AND PUT A NEW FUEL FILTER ON HER AND STILL THE STUMBLE IS THERE. THIS WEEKEND I AM GOING TO HAVE THE INJECTORS FLUSHED AND SEE IF THAT HELPS. I WOULD APPRECIATE ANY HELP I CAN GET ON THIS. I LOVE THE CAR AND WILL GET IT FIXED ONE WAY OR ANOTHER.....
Old Aug 26, 2008 | 07:22 PM
88rocksu's Avatar
Default RE: SAD NEW CAMARO OWNER.
Old Aug 26, 2008 | 07:57 PM
02StanGT's Avatar
Coil pack maybe. What is the other cylinder that is misfiring?
Old Aug 26, 2008 | 08:04 PM
RFxCamaro's Avatar
man this just happened to another member and also myself, first thing i would do is check your vacuum line because its whats wrong with mine, if i go pass 4rpm about it will buckle and then stall if i idle this repair will cost no more than $50 if you do it yourself, by the way all 3 of us have the 3800 engine so im pretty sure that this is the problem with it
Old Aug 26, 2008 | 11:03 PM
evilkal's Avatar
I disagree.... Because when he stomps it, he misfires... A vacuum line would do it all the time at any given point... I'm betting on a coil pack :$
Old Aug 27, 2008 | 05:00 AM
88rocksu's Avatar
I WAS THINKING COIL PACK AT FIRST BUT THEN I HOOKED UP THE TECK II AGAIN AND WOULD GET DIFFERENT CYL. CODES.
Old Aug 27, 2008 | 06:28 AM
th3po1son's Avatar
take
your
caps
lock
off
Old Aug 27, 2008 | 09:45 AM
evilkal's Avatar
Then the control module may be shot or you need to replace all 3 coil packs?
Old Aug 27, 2008 | 05:04 PM
88rocksu's Avatar
WHERE WOULD THE VACUUM LINE BE THAT YOU ARE REFERRING TO BE ?
Old Aug 27, 2008 | 05:59 PM
th3po1son's Avatar
ORIGINAL: 88rocksu
Thanks for the computer help... I guess I know who to go to when I need help on the computer insted of car repair.
caps lock is annoying. simple as that.
you dont need to be an *** about it.
i mean seriously, you REALLY had to send me an email about that? really????
whatever.
btw, dont reply to this.
