SAD NEW CAMARO OWNER.
Old Aug 27, 2008 | 06:21 PM
evilkal's Avatar
Default RE: SAD NEW CAMARO OWNER.
If you want help with car repair without being a ****head... Then yeah we can do that... Otherwise, go find a mechanic who knows nothing about your car and ask him and kindly leave us alone. Caps lock is really annoying and pisses people off.... Simple right?
Old Aug 27, 2008 | 10:58 PM
RFxCamaro's Avatar
Old Aug 28, 2008 | 12:29 AM
noz's Avatar
noz
if the vacuums are alright and the coil packs too check your injectors they might be plugged or broken do an injector test....
Old Aug 28, 2008 | 01:17 AM
evilkal's Avatar
Noz has a good point. But your computer would have a bank reading lean if it was injectors.
Old Aug 28, 2008 | 05:18 PM
02StanGT's Avatar
Which cylinders are misfiring? You said one, but did not name anymore.
Old Aug 28, 2008 | 07:35 PM
88rocksu's Avatar
The first time Hooked the tech II it was showing the #5 cyl. I drove it 4 a couple of days with the hard on pedal stumbel than checked it again and it was bouncing around all cyl but 1 and three was the worst. I changed the fuel filter but still it stumbles. Today I unhooked the MAF and still it stumbled.The next thing I think to do is have the injectors flushed. Then maybe O2 sensors. I guess????
Old Aug 29, 2008 | 11:37 AM
95slvrZ28's Avatar
If you unhooked the MAF and the car is still misfiring it's not a problem with the O2 sensors since they have to input to the fuel mixture when the MAF is not plugged in.
Old Aug 29, 2008 | 11:45 AM
02StanGT's Avatar
Do they not make slight adjustments for the MAF as well? Which would mean they are an input anytime in closed loop.
BrianJackson128
Mar 14, 2014 10:51 AM
MastaGunZ
May 29, 2012 02:54 PM
WindyCitySuperSport
Oct 31, 2011 06:48 PM
9434V6
Aug 18, 2011 07:53 PM
NEBScamaro91
82-92 V8 Tech
Mar 19, 2010 07:20 AM
