A new noise
Old May 18, 2013 | 06:18 AM
Rhapsk's Avatar
Default A new noise
So, I posted a while back about a certain noise my car was making and changing the fuel filter solved it.
Now I have a noise sometimes when I cold start the car and it's basically this sound:
The starter we have in it makes a clicking sound like that when it starts the engine, but it usually goes away within 1 second of starting.
Now, though, the sound remains for a while sometimes and eventually dissipates. It does this on and off as some days it doesn't occur. I also sometimes notice a very tiny amount of the clicking on occasion when I'm at high RPM as though it is correcting itself out and then it's gone.
Is the starter going bad? Is it one of the pulleys/belt? Should I check the battery?
Old May 18, 2013 | 08:34 AM
2Z's's Avatar
Sure seems like the starter is the probem. Perhaps the solenoid is faulty... not letting the armature fully disengage or engage sometimes when it shouldnt.
Old May 18, 2013 | 11:09 AM
Jim in Indy's Avatar
The video & audio help a lot.
Do you have any shims between the starter & where it bolts up at??
It sure seems to me like a slight shimming of the starter away from the flywheel teeth a few thousandths may be what's needed.
Crabby may want to sound off on this also, but it almost seems like the teeth are meshing to 'deep', leading to a rough engagement & slow disengagement of the drive .
Old May 19, 2013 | 08:07 AM
Cool
yep sounds like the stater needs adjusted.
https://camaroforums.com/forum/gener...himming-20175/
B_Dubya
Mar 27, 2015 02:10 PM
DashingDaryl
Apr 4, 2012 02:46 PM
AKLDan2k1
Aug 23, 2011 07:56 AM
supreme_style21
Jun 8, 2010 06:36 PM
EddieTheRipper
Oct 11, 2007 08:57 PM
