Need some help, Suspension issue
Old Apr 7, 2012 | 10:28 PM
the upper ball joints last way longer than the lower. have you looked at the tie rod ends? very common for them to wear out. i have a used front sway bar for a 93 z28. where you at?
Old Apr 8, 2012 | 12:56 PM
kkobberstad's Avatar
I am in michigan, but am going to maryland for the summer. But I definitely needed to replace the upper ball joints. The drivers side was shot. The upper ball joints made a difference. I am thinking that I should take a whack at the lower ball joints.
Old Apr 8, 2012 | 01:27 PM
if they are still original then they should have wear indicators on em. that may give you a idea. Ball joints
Old May 15, 2012 | 02:07 PM
BigCat2010's Avatar
Hey found something that might help you out while I was browsing online. I remembered you posting on here a little while back...
RKSport - The Performance Styling Specialists
These are supposed to elimitate some of that bumpsteer problem.
GaToy
Apr 10, 2011 08:53 PM
fatherdaughterproject
Sep 11, 2009 11:36 PM
IROCNeeveeZ28
82-92 V8 Tech
Aug 26, 2009 05:29 PM
steve1967
Oct 6, 2007 11:06 AM
