rear suspension issue
Old Sep 29, 2007 | 12:34 AM
steve1967's Avatar
Default rear suspension issue
I bought my 67 camaro recently and driver side sits lower than passanger. I noticed that the shock plate in rear was the same one that was on passanger side, but it was flipped over. I hear that 67 camaros only came with a mono leaf spring. mine has 5. how do I go about finding a plate that will work with what I have, would a 68 style work for me.
Old Sep 29, 2007 | 12:14 PM
1969 SS's Avatar
Default RE: rear suspension issue
the 68/69s are the same as eachother, while the 67 isits own piece.
68/69 still could have monoleaf springs.
if you have a multileaf pad, it will just be pretty much flat with on high raised side, if you have an adaptedmonoleaf pad under there (which I don't think you do), you will have two eye holes coming off of one side of the pad and another arm coming out the side 90 degrees from the two eyeholes
hope this helps?
Old Sep 30, 2007 | 01:15 AM
steve1967's Avatar
thanks for the reply , but what I really need to know is if a shock absorbing plate off a 68 or 69 would work.
Old Oct 6, 2007 | 11:06 AM
1969 SS's Avatar
ORIGINAL: steve1967
no, because shocks on a 67 both mounted up on one side of the rearend and 68/69 staggered their mounting points
the 67s are still widely available so you shouldn't have to be worrying about adapting a different year
kkobberstad
May 15, 2012 02:07 PM
LittleBill
Mar 13, 2009 03:37 PM
Red86
Aug 8, 2008 09:13 PM
z28rob18
Jul 3, 2008 02:33 PM
