Need some help, Suspension issue
Well I am not quite sure what is going on, but maybe I can get some help from you guys! =)
I have a 1995 3.4l, and I am having some steering issues. I have had two alignments to try and correct the problem, but to no avail. My car seems to steer with the road. The steering will follow the gradients in the road, like if it is wavy, or inclined to the left or right. In other words, if the road is not perfectly flat, it will make me steer against it. Any ideas??
Thanks a bunch!!
-Ken
Thanks a bunch!!
-Ken
@liberty can wider tires really cause this? I did have an accident involving me smashing into a curb so hard that I broke an oem wheel.... =( but now I have 18x9.5's on all 4. not sure what the offset is on them. This was driver's side front btw. I have noticed that the sway bar no longer sits flat on the bushings on that side, and I am thinking that it is bent. Could this have an effect too?
@bigcat I keep them all around 38 psi. I believe that they are 255/40/18's, but they are have a relatively tiny sidewall, so I make sure to keep them fully inflated!
Just looking at bushings will not tell you if a sway bar is bent usually. Of course any bent suspension parts or frame will affect the way the car drives. Did you have anything else adjusted/replaced along with that accident? If not, it is very likely other damage was not repaired -- may want to take it to a reputable body shop that specializes in frame/suspension repairs from accidents.
Wide tires can and do tramline, i.e.:
http://ls1tech.com/forums/suspension...light=tramline
Tramlining! That is exactly what I am experiencing. I don't really want to take it in to have it looked at... rgh. Since this accident, I have replaced all of the springs and shocks/struts. I do in fact have a bad strut which could be an issue, but the tramlining has been going on for almost a year. I dunno. Also the sway bar looks bent because a curve in it is much more sharp on one side than the other. Also I have replaced the upper ball joints. Maybe I should replace the lower's as well?
well, from that thread, I gathered that any worn or damaged suspension components can make tramlining worse, and with "grippy" tires you're always going to have it to some degree. So, I would say that you're best bet is to fix the things you know need fixing and go from there.
Also, i was unable to find any information on my tie rod ends. I "misplaced" the receipt for them. My apologies.
