Heat Gauge issues
Old Feb 18, 2019 | 06:52 PM
hawks000's Avatar
Default Heat Gauge issues
I am working on a 1999 3.8 Camaro for a friend I ended up putting both lower/ Upper intake gaskets on PITA... but got it completed and started the car & let it run while getting air out of the coolant system while I worked on another problem , I mean car when I came the Camaro's coolant gauge was sitting WHY past 260 , it was pegged out. I assumed it was a bad sensor, went and got a new one & it's doing the same thing. I have verified with a inferred thermometer that is NOT that hot! Has anyone of you ran into an issue like that before ?
Just FYI the owner swears the heat hand was working correct before i worked on it
Also his RPM needle stays @ 7 or more, I'm wondering if it could be something in the cluster or a wiring issue ?
Thanks in advance
Old Feb 18, 2019 | 10:40 PM
look for a grounded wire going to the sensor, did you even unplug it during the original work? check for any wires around the intake to make sure none got squished when you was installing.
typeomang
Jul 31, 2022 08:38 PM
daves86
82-92 V8 Tech
Aug 23, 2012 08:16 AM
ianlove17
Jul 19, 2012 01:23 PM
ChevyManCam
Jun 8, 2011 09:23 AM
whits_iroc
Dec 4, 2008 02:10 PM
