Fuel Pump?
Old Jun 24, 2007 | 04:47 PM
ArcadeMike's Avatar
Default Fuel Pump?
Quick question. Will the fuel pump still kick on for a few seconds when you turn the key to the ON position before starting even if the vats / passkey is wrong? I made the resistor jumpers but the fuel pump will not build any pressure at any time. I checked the fuses and relay and they are ok.
Thanks,
Mike
Old Jun 25, 2007 | 08:42 PM
nuttyprofessor's Avatar
Default RE: Fuel Pump?
I believe it will you just won't get any spark...can't remember since it's been such a while since i had this happen before.....someone correct me if I'm wrong
Old Jun 25, 2007 | 10:07 PM
The PCM won't bring up the fuel pump relay if it does not see an enable signal from the VATS module. Could be the resistors, wiring, the VATS module, pump relay, or the pump.
jon_uscg2001
Aug 25, 2011 12:23 AM
nehidustin
Jun 28, 2010 07:30 PM
carmodder
82-92 V8 Tech
Jun 23, 2008 12:50 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
