Front suspension questions
Old Oct 15, 2012 | 01:14 PM
REN's Avatar
REN
Default Front suspension questions
Hi removed front struts:
1-broke the sway bar end rod, any recommendations or are they all about the same?
2-upper ball joint bushing is worn, is it easy to get the control arm off? see photo
3-should i bother with the lower ball joint or do you need special tools to get that off.
4- upper strut plate insulator is old but not worn, they are about $17 on Rock auto, worthwhile ? see photo
Attached Thumbnails Front suspension questions-upper-control-arm-old.jpg   Front suspension questions-strut-mount-bushing.jpg
Old Oct 15, 2012 | 01:30 PM
if your lookin at getting a sway bar anyways look at strano's rear front sets. like mine.
no not easy to get off and a pita to change.
lower ball joint is the ones that fail first and most. not easy to change, i had shop do mine.
yes replace and when putting back together grease the heck outa it. once its covered they rust as you can see so lots of grease will prevent
phat69Camaro
Apr 17, 2014 02:20 PM
kenjames23
Feb 11, 2014 05:43 PM
KiddCamaro
Aug 27, 2011 10:16 AM
94CamaroSFI
Apr 24, 2007 03:27 PM
chvy79z
May 4, 2006 11:15 PM
