Fan wont turn on unless a/c is on
Per Autozone.
Coolant temperature sensor is located
Under hood, center, upper engine area, rear of water outlet, mounted in intake manifold
The Cooling fan switch is located
Under hood, passenger side, lower engine area, below exhaust manifold, mounted in engine block
Osduck,
I went looking around this mornig and only found one sensor on the passenger side.
It is located just in the front of the starter and not by any dipstick. It does not look like it's a coolant sensor. It is quite a bit bigger and looks like its the knock sensor.
Where could I find the picture your were refering too?
