Fan wont turn on unless a/c is on
Old Mar 25, 2010 | 04:40 PM
smoothdog11's Avatar
Question Fan wont turn on unless a/c is on
Help Please!
I have a 92 RS with a 3.1 and an auto tranny with just over 100,000
My car overheats anytime it is at a long stoplight or a drivethrough because the radiator fan will not turn on.
I can make the fan come on by either turning on the a/c or unplugging the coolant temp sensor.
I have replaced the relays, coolant temp sensor and the ECM(twice).
I just am not sure what else it could be.
Please help!
Thanks!
Old Mar 25, 2010 | 07:14 PM
microkid's Avatar
March 2011 ROTM
Technical User
dont trust the factory gauge for an accurate temp. ive encountered a few that read off by +/- 30 degrees. what temp is it reaching, what is its normal operating temp, and is a single or dual fan setup?
Old Mar 25, 2010 | 08:25 PM
Turn the key to the "on" position and check the temp sensor to ensure you're getting voltage to it. No voltage means no fan. Once you're sure the sensor has voltage, then let it idle until the temp gets high enough for the sensor to close and check to see you're getting voltage to the fan. The fan motor might be gonzo.
Old Mar 25, 2010 | 09:38 PM
Thanks microkid but the temps are all accurate. The car runs at around 180 and will get as hot as you will let it.
Also thanks 1971bb427 but the fan works when I disconnect the temp sensor or turn the a/c on, so the fan motor must still be good. There is power to the sensor and when unplugged the engine light comes on.
Any other ideas would be greatly appreciated!
Thanks again!
Old Mar 25, 2010 | 09:59 PM
carguy68ssrs's Avatar
Did you change the sensor for the fan or the gauge? I think the fan has it's own sensor to turn it on and the stock setting is pretty high, like 210 or something
Old Mar 26, 2010 | 09:06 AM
blackz87's Avatar
The fan is hooked up to the A/C and only turns on when the Temp hits 220 degs. These cars were made to run Hot.
Old Mar 26, 2010 | 11:29 AM
Oops! You did say it ran with the AC on. Sorry.
Old Mar 26, 2010 | 11:41 AM
have u got a chip on the prom? like a hypertech.
Old Mar 26, 2010 | 11:50 AM
No chip, just the stock prom.
The car is all stock with only delco parts
Old Mar 26, 2010 | 11:52 AM
Thanks BlackZ87 but the problem is it does not turn on at 220.
It will get hot enough to do damage and the fan still does not come on.
