Engine Replacement help LT1!
Old Dec 12, 2015 | 01:46 PM
Cocoiscool's Avatar
if you take it out from under yes i have seen people due it if you take out from bottom ,with mine ,we were also takeing out 90% of my wireing too,,couse with my swap I would not need ,just seems to me its longer to take out under the car an more to take apart ,then over ,you have to be able to lift the front of the car with a strap ,if you have an engine puller that helps , then pull it out still attached to the sub frame cross member wheels an all ,with all the help you got ,you should be fine either way ,dont forget to post pictures ,there are other threads hear of guys takeing it out from under ,in the projects section,post another thread in the projects section ,an if you if you do it well it could be used bye others
Definitely will post it in the projects
rwing7486
Dec 1, 2009 10:23 AM
zdav28
Oct 31, 2009 05:36 PM
mmacioce
82-92 V8 Tech
Jun 29, 2009 08:08 AM
karlisdad2005
Apr 15, 2009 12:26 PM
sdt1985
Feb 17, 2007 05:06 PM
