Door doesn't open from the inside
Old Nov 29, 2014 | 06:42 PM
pcarollo's Avatar
Default Door doesn't open from the inside
My 94 Z28 drivers side door just quit opening from the inside. From what I've read it sounds like some sort of clip that's broken as I am able to open it from the outside. So I will need to remove the door panel and fix this, does anyone have instructions on this? So many plastic pieces...I would like to know what everyone else has done to fix the problem. What is the technical term for these clips? The door was closed, slammed actually, and since then it has been a problem.
Thank you!
Old Nov 29, 2014 | 07:53 PM
Go to the manual section and get the GM manual, Also try a search on you tube.I did a quick one for Camaro doors.
Old Nov 29, 2014 | 09:38 PM
at about 3'26" on the recording above you see the bar that runs from the handle to the lock. make sure thats connected at both ends.
Old Dec 1, 2014 | 09:36 PM
GaryDoug's Avatar
Items 16 and 56: http://parts.nalleygmc.com/showAssem...category=19392
These may help:
Airforcebob
Aug 12, 2013 05:59 PM
Anthony17
Mar 22, 2012 12:44 PM
robmnrd
Jul 22, 2010 11:19 PM
AlwaysWantedA55
Mar 23, 2010 07:48 AM
gregm999
Oct 17, 2007 06:19 AM
