Coolant hose
Old Sep 4, 2015 | 03:20 PM
Tanner Scadden's Avatar
Default Coolant hose
First time posting here! Just bought a 96 camaro a few weeks ago, and could use some help.
It looks like there is a hole where these two parts connect. I was wondering if anyone knew what part number this was so I can get it fixed and get the Camaro back on the road! Its causing it to smoke decently with the coolant hitting the engine block.
In the picture its the metal connecting to the line behind where you put the oil in.
Imgur: The most awesome images on the Internet
Old Sep 4, 2015 | 04:08 PM
If I understand your question right that is one of 2 heater hoses. It should connect to the heater core at the fire wall and run up to the water pump.
Old Sep 4, 2015 | 08:07 PM
looks like someone replaced one of the heater hoses. so your talking about the one thats left with metal pipe. where is it leaking, the hose or the pipe? you can replace the hose on the pipe. 4th Gen LT1 F-body Heater Hose R&R or if you feel you can route the hose without it burning replace metal with hose.
Old Sep 4, 2015 | 08:14 PM
I already ordered a part for it from v6parts I believe it was. It was an afte
Old Sep 4, 2015 | 08:16 PM
I already ordered a new part from v6parts I believe. Was cheaper then getting one from the dealership for $200+.
Is there a way I can fix this problem until my part comes next week? I will only drive the car once with the temp fix. It's a pretty bad leak though, so not sure if there is a way.
Old Sep 6, 2015 | 04:08 PM
Everett#2390's Avatar
Welcome, Tanner.
You're best bet is get a Haynes manual for reference.
Old Sep 6, 2015 | 05:51 PM
bypass the heater core. you run the hose from the water pump to where the other heater hose goes to. on mine it goes back to the water pump with some going to the radiator that goes through the thottle body. not sure how it goes in the v6. just follow both hoses from the heater core/firewall.
carlocamaroVA
Feb 5, 2013 02:09 PM
hooknladder
Apr 15, 2011 08:50 PM
mab6680
Dec 23, 2010 08:01 PM
AnalyzeFaith
Dec 5, 2010 05:54 PM
Ganon00
May 1, 2009 08:33 PM
