Coolant hose question
Old Apr 14, 2011 | 11:38 PM
hooknladder's Avatar
Default Coolant hose question
97 Z28 LT1. One of the smaller hoses coming from the water pump. The bottom one which has a metal coupler about 8-12" from where it connects to the pump. It appears to go almost straight down and then comes up and runs along the passenger fender and turns into a metal line that goes back to rubber where it appears to go to the heater core. If you followed me that far, it has a leak at the metal part just off the water pump. Do I have to replace the whole thing, or is there a kit to splice in instead of replacing all the metal lines? I haven't priced it yet but i bet it is big $$$ and probably a GM only item. It is a slow drip but want it cured before it gets hot out. I just had the water pump replaced a month ago and maybe it got twisted or something and started to drip around the metal coupler. Any guidance would be appreciated.
Old Apr 15, 2011 | 11:41 AM
You can replace the entire line with a section of heater hose, much cheaper than the stock type hose/pipe unit.
Old Apr 15, 2011 | 08:50 PM
Ok thanks. I wasn't sure if the metal coupler looking part actually did anything. I think instead of splicing I will do that, although that line looks like a bear to get away from the inner fender.
belairbrian
May 19, 2014 04:03 PM
blackbeauty1995
Dec 22, 2013 08:32 PM
carlocamaroVA
Feb 5, 2013 02:09 PM
AnalyzeFaith
Dec 5, 2010 05:54 PM
Ganon00
May 1, 2009 08:33 PM
