hose hose and more hose
Old Dec 23, 2010 | 05:50 PM
mab6680's Avatar
Default hose hose and more hose
ok i have a 97 z28 all of the hoses are just about shot i have had the upper rad hose go as well as both the heater hoses right at the water pump so i was able to just cut a piece off and put it back on i have also had a water pump gasket blow out i want to change all of the hoses my question is i want to change the heater hoses the ones that are mostly metal these look like a real pain in the you know what has any one change these are they as hard as they look id so can i just run rubber heater hose from the pump to the core one has a bleeder screw and the other one comes off the pump and then there is some kind of weird section thats about 3 inches long and is fatter then the rest of the hose it almost looks like one of those steal braided exhaust flex joints just made out of rubber anyone know what that is
Old Dec 23, 2010 | 06:36 PM
osduck5's Avatar
Check out this link
http://www.fbodyonline.com/forum/f16...-repair-44783/
If you are going to get the original, you will have to order from dealership or hunt some used ones at a slavage yard or ebay. There is one torx screw that attaches the hoses to the inner fender and it is just a matter of getting the clamps off the heater core.
Old Dec 23, 2010 | 07:44 PM
mab6680's Avatar
i dont have those wierd metal fittings my clamps on the heater core are just those hose clamps that you sqeeze the two tabs together and slide it down
Old Dec 23, 2010 | 08:01 PM
osduck5's Avatar
That link is to show you an option for repairing them unless you want to drop about $180 for the new ones.
Don't be fooled about those clamps that squeeze together being easy to get off and on, especially if they have never been off. But they are easier to get off than to get back on.
black95z28
Apr 19, 2010 11:28 PM
Tonylig928
Dec 30, 2009 07:38 PM
ShiftyMcCan
82-92 V8 Tech
Aug 23, 2008 04:14 PM
chrshadil
Aug 21, 2008 11:37 AM
TomS68
Apr 4, 2008 09:52 AM
