Compressing drum parking brake spring
Old Oct 18, 2020 | 05:54 PM
vipe155's Avatar
Default Compressing drum parking brake spring
I'm having a little trouble finishing off some brake work. 1995, with rear drums. I pulled the parking brake spring/lever off the cable end because the parts after all these years were pretty rusty. I didn't think it would be too hard to get them back on. Problem is, the springs on these are pretty substantial (more than a lot of other springs in other cars I've seen in videos online), and I can't compress the things down enough to get the lever back on. A special Lisle brand tool made for this job wouldn't work for multiple reasons, and I tried using zip ties to compress it down only to find that the cable end is too big to fit back through the spring with the zip ties on there as well.
Any ideas? Thank you anyone that has a trick to do this.
Old Oct 19, 2020 | 11:58 AM
HenryC's Avatar
Sorry for the not being much help but why wouldn't a regular spring compressor work for this?
Old Oct 19, 2020 | 02:03 PM
vipe155's Avatar
Maybe something like that would work, but I'm not really familiar with them. The only ones I've seen used online, or are available to loan out locally seem to be meant for large suspension coil springs.
Old Oct 19, 2020 | 06:22 PM
Have you tried disconnecting the other side sliding the the cable out.
Old Oct 19, 2020 | 07:38 PM
vipe155's Avatar
I'll look at the shop manual on how that works or whether you need a certain tool for that. I'm wondering if the tension of the spring being on the drum end would make it hard to reattach the cable under the car.
Old Oct 19, 2020 | 08:26 PM
peterpar's Avatar
While you're in the service manual, check out the installation of a new cable. It should explain the procedure for attaching the new cable. It is possible you may have to disconnect the opposite end of the cable to get the slack you need.
Old Oct 24, 2020 | 08:17 AM
Might seem like a dumb or obvious question, but I have to ask. You don't have your parking brake lever pulled up, do you?
Old Oct 27, 2020 | 04:36 PM
vipe155's Avatar
Thanks everyone for the ideas. I was able to get under the car, and push out enough slack to the drum to wrestle one sides spring/lever on. Then when I moved to the other side, it was now easier to pull out enough cable to get that side done.
madhatter98
Feb 1, 2011 05:16 PM
hkunz
Oct 10, 2010 07:05 PM
longwell
Feb 4, 2010 12:22 PM
th3po1son
Nov 29, 2008 01:50 AM
85z285.0
Apr 19, 2008 10:22 AM
