Need help loading on trailer.
Old Oct 30, 2020 | 07:08 PM
1superchevy's Avatar
Default Need help loading on trailer.
Hello all. I need help. I traveled a long way to pick up my old Camaro. Off course I brought the key to the firebird instead. How do I turn the wheels if I can't unlock the steering wheel? It's a 4th. Gen. Thank you.
Old Oct 31, 2020 | 08:17 AM
You can't turn the ignition with no key without damaging it. In the engine bay, there is one bolt that attaches the steering shaft to the base of the steering column. Remove that bolt and pry on the end with a screwdriver to slide it down and away from the column. You now will be able to turn the wheels, by hand.
BirdmanBroham
Apr 11, 2019 01:33 PM
MJTate
Jun 25, 2013 06:26 PM
hottroddin
Mar 8, 2012 08:05 PM
cdl.computersinc
Feb 16, 2010 12:58 AM
ajk511
Oct 9, 2006 08:08 PM
