V6 TBW to cable throttle
Old Oct 30, 2020 | 11:28 AM
Chantz Webb's Avatar
Default V6 TBW to cable throttle
So I’m swapping a 2000 engine into my 96, the 2000 has Throttle by wire, can I just switch out the throttle body for the one on my 96 and run it or is there something else I need to do?
Old Oct 31, 2020 | 09:38 AM
yes, you will of coarse need to switch over any thing else that is not the same as your 96 setup.
Old Oct 31, 2020 | 09:59 AM
ok, but any idea what all that might be? Or are all parts interchangeable? Such as upper intake manifold, valve covers things like that? I’ve received various answers to this... some say that the 96 3.8 series 2 is different than the 2000?
Old Oct 31, 2020 | 11:08 AM
2000 Camaro motor?
Old Oct 31, 2020 | 01:01 PM
HenryC's Avatar
I don't see why this wouldn't work, the only reason it wouldn't is the diameter of your upper intake manifold is different than that of your 96 throttle body. I think that the 96 upper intake manifold should just bolt up to a 2000 camaro motor. Someone else can clarify.
Old Oct 31, 2020 | 01:07 PM
that’s what I am hoping but still waiting for some clarification 😉
Old Nov 2, 2020 | 07:08 AM
I would pull the lower intake on the new motor anyways to replace the gaskets. then you will see if there is a difference and if there is use the 96 one. if its a 2000 camaro engine it will fit.
Old Nov 2, 2020 | 07:27 AM
thanks! And gorn PM’d me back and said it should all swap, hoping the gasket set that I had previously ordered for the 96 will work....felpro said there was difference in heads and everything but from reading here he didn’t know what he was talking about😉
Sicilian
May 17, 2013 07:59 PM
thetal1
Jul 6, 2010 11:28 AM
Blade
May 24, 2008 10:02 AM
microkid
Jan 21, 2007 04:22 PM
WMadam11
Nov 7, 2006 07:47 PM
