Changing Front Struts on 1998 Camaro
Old Jun 6, 2009 | 01:04 PM
Camaro3800V6's Avatar
Great---thanks!
Old Jun 8, 2009 | 01:57 PM
Okay, one more dumb question. Will a standard strut spring compressor work on these springs??? The compressor I have has 2 hooks top and bottom....just wondering if it's going to fit the smaller Camaro springs, or if I need to go out and buy a special compressor.
Old Jun 8, 2009 | 02:12 PM
the one u have will work.
Old Jun 9, 2009 | 06:22 AM
I've got problems!!!
I got the struts out of the car last night, no issues, and then I saw the strut mount nut. The main nut holding the mount onto the strut shaft is BADLY rusted, to the point of crumbling, on both struts. They're seized to the shafts, and I can't get them off. Sockets, hammed on, just keep rounding the nuts down smaller and smaller. I tried to cut the nuts off with my angle grinder, but it can only go through half of the nut before it starts to contact the strut mount. What do I do????? Strut mounts for these cars are $80 each, I really don't want to destroy the ones I've got....
Old Jun 9, 2009 | 07:34 AM
i used a chissel and a hammer carfully. wellll as carfull as i could. make sure to lube them up with some anti seize before putting them back together.
Old Jun 9, 2009 | 07:40 AM
Thanks, I'll try that when I get home from work.
There's not enough play in the strut mount to have to worry about needing an alignment when all of this is done, right?
Old Jun 9, 2009 | 03:16 PM
u will need to get it aligned. after everything the last thing u want to do is ruin a set of tires. when u have it all apart and put it back it changes things a little and add to that new parts that will change things a little more. only takes a fraction of an inch. now u know y its good to lube up that bolt on the front. not such a big thing on the back shocks. it took quite a while to cut the bolt with the chisel making sure not to hurt the mount. didnt worry bout the old shock shaft though.
95z28man
Oct 11, 2015 12:54 PM
longarmperrin
Dec 17, 2010 08:55 PM
serg83
Jun 27, 2009 09:02 AM
hevymetalg
Mar 30, 2008 11:19 PM
ARAKND!
May 8, 2007 02:12 PM
